hello
Please your help to create a solid surface geometry from that I developed for Dynamo. At one end of the surface must have height = 25cm and the other end must have height = 15cm. How do I show in Revit?
Thank you very much for your help.
regards
David
Hello David Martinez,
You can use below nodes to make Solid and then get that solid in to Revit.
Pass off of your curves to PolyCurve.ByJoindCurves
Thanks,
Ritesh
Hi Ritesh
Thank you very much, nodes worked well !!.
Is it possible that one end has a height of 25 inches and the other end of 15 centimeters? In my first post this screenshot.
regards
David
