So far I have tried using the family types drop down and leaving it blank as well as choosing an option it it for None. both of which don’t seem to work.
Let your dyn. create the Sheets WITH a (random) Title Block.
Remove the Title Block aftter you created the Sheets.
This leaves you with Sheets with no Title Blocks.
That worked. thanks Imran ! Thanks also for the help BVS I can indeed just delete the titleblock once its been created.
No way to choose None for the title block then I assume, it would save the need to have another title block in the template specifically for this workflow.
You need to call up “ViewSheet.Create(doc,ElementId.InvalidElementId)” in a Python script. If like me you don’t really know what you’re doing in Python, you can find a custom node, edit it and hack something together (edit the line that would normally call up a titleblock variable to instead have the invalidID as above) to do what you need then bring it into your main script.
