Create Sheet Set (print set) in Dynamo 2.6
I am by no mean an expert or even beginner in dynamo. I try to find something online and try to use it. I used to have a script for creating sheet set in revit based on the given revision on the sheet. Now that script doesn’t work. I downloaded 4 different script from others and still keep getting error (either from archi-lab node or orchid). is it possible that there is lack of compatibility of older scripts with 2.6?
does anyone have a script that works in 2.6? sorry I cant attach the one I have due to being a new user. if you have something that is simple to use, or even a guide to make my own, I would appreciate it.
Thanks :slightly_smiling_face:
Thanks. This is a very interesting addin. I don’t believe it can automatically create sheet set which certain revision on them.
I wanted to lets say i have revision 2 on 10 sheets. I want see create a sheet set of any sheet with revision 2 on it.
This should solve your request.
Create sheet sets.dyn (19.5 KB)
Thanks again.
When I open the file this is what I see. i dont know why its showing like this.
also made dynamo laggy and kept freezing
I cant replicate your solution either due to node names not being visible in your attached image
@Soroush.Bahrani try to replicate this:
I used the Revision description but can be anything you like (number, date…)
Hello @Soroush.Bahrani and welcome
you can try this (with Python)
I figured what was causing Dynamo going all crazy. it was the pyrevit addin. your first post works now.
is there a way to say create set only from chosen revision rather than all revisions in the project? there is a “select revision” node but I am not sure how it would fit in your dynamo script
Try this
Thanks for all of the posts. I’ve tweaked it a bit as I needed to create the Print Sets from a parameter that was used to organize the Sheet Browser. I added a dialog box to ask which value of the parameter to create the set from. My export image isn’t working so the following is a screencapture.
Create Print Set from Selected Sheet Category.dyn (39.3 KB)
