I’m trying to create wall elevations through dynamo. The way the graph works at the moment is by selecting all the walls, then drawing a line at the base of the wall (to set the extents and direction of the view) and also selecting the line.
I was hoping to make this possible by selecting the face of the wall instead of drawing and picking the line. I’ve had a go in the file attached but I’m having problems getting the direction of the vector correctly when picking the face.
Any help would be appreciated, thanks!
Solved now, if anyone wants to know for future.
I used the select point on face node. Then compared that point to the 2 end points of the wall to return which ever point is closest to the point picked. Now I know which is the start and the end points to give the correct vector direction
hi jimmy ,
can u please share your dynamo script which solves this , cause am trying to create a section by picking curtain wall .
thank u in advance .
