Create Room Schedules from Template
I want to make a simple script that takes a schedule view from Revit, changes the filter (filtered by room), and creates a new schedule named with the room number. Coming from my Grasshopper and Rhino Inside experience, this seems like it should be really easy but I can figure out how to get the referenced schedule from Revit.
Welcome.
How to get help on the Dynamo forums - FAQ - Dynamo
After reading through the above FAQ, I recommend starting with searching through the existing threads. I’m sure I’ve seen this exact request come in at least a few times. There should be plenty documented to get you started.
