Create Room heights from contact others components
hi,
I’m searching for an workfloh, to make room height automaticly by the upper slap.
Somebody an example??
@ghl You can do like this:
  • Set the Upper Limit parameter value which is your room upper level.
  • Set the Limit Offset which is your slab thickness.
I thought you could put an upper limit over the dynamo and the Bounding Box to the overlying floor. The walls can also be aligned to their upper edge, abre that does not seem so simple …
I am looking how to resolve it if the top of the room is covered by a roof curved, pitched but not flat. I am trying to get the internal volume defined by constructive elements.
