Conceptual Mass - can't create roof by face - because it contains only mesh geometry
I have created a script in dynamo, which results in a Surface (Surface.ByPerimeterPoints), that is generated as a conceptual mass in Revit.
I then loaded this new family into my revit project and now I wish to create a roof by face.
However, I get a warning: “Mass contains only mesh geometry, which can’t be used to compute Mass Floors, volume, or surface area.”
I have tried: importing the instance, I have also tried inserting a SAT in a inplace mass. I hoped that the spring node to import a family instance would work, but it did not.
How should I approach this?
Any help would be appretiated!
Conceptual Mass:
Dynamo Script:
Revit Project:
1-094-SA-PAL-EXPO_ATENOR-AQ-R00A_Cobertura52.dyn (262.0 KB)
Hi @RitaAguiar
Looks good to me:
Unfortunately the spring node isn’t running as expected.
It says “Exception: Saving is not allowed. File has been opened by another Revit instance.” and nothing appears on the project.
Do you have any idea why this could be happening?
Restart Revit-> Open Dynamo->Run Again Script.
Unfortunately I couldn’t reproduce what you did…
Can you send me back the dynamo script you ran? Just to be sure i got it right
Thank you so much @Kulkul!
I got it, I have to select a different family, with a thickness less than 0,23 m …
Do you have any idea how can I create this roof with a thickness of 0,9m? There seems to be a limit of 0,23m for the roof to be created.
Is this what you need?
rvt file here ForRita.rvt (1.3 MB)
Almost, I want to avoid the triangulation of the shape. I had to design a shape with a greater area so that I could extrude it with 0,9m of thickness, afterwards I used a Roof Void to cut the excess and obtain the wanted shape, without any triangulation.
Although this is not very ideal, it worked.
