Hi Everyone,
Could you guys please help me out with this error?
It seem like, I put all the correct inputs, but somehow Dynamo can not generate the Rebar…
Dynamo_Rebar_ByCurve.py (1.8 KB)
Here is the script:
import sys
from Autodesk.DesignScript import *
Import Element wrapper extension methods
Import DocumentManager and TransactionManager
app = uiapp.Application
Import RevitAPI
clr.AddReference(“RevitAPI”)
import System
host = UnwrapElement(IN[0])
curves = IN[1]
xyz = XYZ(0,1,0)
style = Autodesk.Revit.DB.Structure.RebarStyle.Standard
rebartype = UnwrapElement(IN[2])
rebarhooktype_start = UnwrapElement(IN[3])
rebarhooktype_end = UnwrapElement(IN[4])
newrebar = Rebar.CreateFromCurves(doc, style, rebartype, rebarhooktype_start, rebarhooktype_end, host, xyz, curves, RebarHookOrientation.Right, RebarHookOrientation.Left, True, True)
OUT = newrebar
