I need to use Rebar.CreateFromCurves method in Python but I am getting some errors. I dont know how to resolve. It will be helpful if somebody give some suggestion
I’ll give the source code here
import sys
clr.AddReference('RevitAPI')
from Revit.Elements import *
import System
from System.Collections.Generic import List,IList
clr.AddReference('DSCoreNodes')
from DSCore.List import Flatten
# Inputs
surface = IN[0]
sideOffsetDistance = IN[1]
topOffsetDistance = IN[2]
bottomOffsetDistance = IN[3]
offsetFromFace = IN[4]
rebarType = UnwrapElement(IN[5])
selectedElement = UnwrapElement(IN[6])
rebarHookType = UnwrapElement(IN[7])
# Hardcode Values
dummyOffsetDistance = 0
u = 0.5;
v = u;
# Extracting Edge curves from surface
tempList = [Surface.PerimeterCurves(edge) for edge in surface]
edgePerimeterCurves = Flatten(tempList)
firstEdgeCurve = edgePerimeterCurves[0]
secondEdgeCurve = edgePerimeterCurves[1]
thirdEdgeCurve = edgePerimeterCurves[2]
fourthEdgeCurve = edgePerimeterCurves[3]
# Get Start and End Points of the Curve
def getCurvePoint(curve, key) :
    if isinstance(curve, Curve) and key == "sp" :
        return curve.StartPoint
    elif isinstance(curve, Curve) and key == "ep" :
        return curve.EndPoint
    else :
        return None
startPointFirstEdgeCurve = getCurvePoint(firstEdgeCurve, "sp")
endPointFirstEdgeCurve = getCurvePoint(firstEdgeCurve, "ep")
startPointSecondEdgeCurve = getCurvePoint(secondEdgeCurve, "sp")
endPointSecondEdgeCurve = getCurvePoint(secondEdgeCurve, "ep")
startPointThirdEdgeCurve = getCurvePoint(thirdEdgeCurve, "sp")
endPointThirdEdgeCurve = getCurvePoint(thirdEdgeCurve, "ep")
startPointForthEdgeCurve = getCurvePoint(fourthEdgeCurve, "sp")
endPointForthEdgeCurve = getCurvePoint(fourthEdgeCurve, "ep")
# Offset Point Getting algorithm
def offsetPoint(startPoint, endPoint, offset) :
    x1 = startPoint.X
    y1 = startPoint.Y
    z1 = startPoint.Z
    x2 = endPoint.X
    y2 = endPoint.Y
    z2 = endPoint.Z
	# Direction Vector
    dx = (x2 - x1)
    dy = (y2 - y1)
    dz = (z2 - z1)
	# Magnitude
    magnitudeOfDirectionVector = (dx*dx + dy*dy + dz*dz) ** 0.5
	# Normalized Direction Vector
    ndx = dx/magnitudeOfDirectionVector
    ndy = dy/magnitudeOfDirectionVector
    ndz = dz/magnitudeOfDirectionVector
	# Scalling the normal to the Side Offset Distance
    sx = offset * ndx
    sy = offset * ndy
    sz = offset * ndz
	# Point at the given distance on the first edge
    return Point.ByCoordinates(x1 + sx, y1 + sy, z1 + sz)
# Finding Cover Offset Points
edgeOneOffsetPointOne = offsetPoint(startPointFirstEdgeCurve, endPointFirstEdgeCurve, sideOffsetDistance)
edgeOneOffsetPointTwo = offsetPoint(endPointFirstEdgeCurve, startPointFirstEdgeCurve, sideOffsetDistance)
edgeTwoOffsetPointOne = offsetPoint(startPointSecondEdgeCurve, endPointSecondEdgeCurve, topOffsetDistance)
edgeTwoOffsetPointTwo = offsetPoint(endPointSecondEdgeCurve, startPointSecondEdgeCurve, topOffsetDistance)
edgeThreeOffsetPointOne = offsetPoint(endPointThirdEdgeCurve, startPointThirdEdgeCurve, sideOffsetDistance)
edgeThreeOffsetPointTwo = offsetPoint(startPointThirdEdgeCurve, endPointThirdEdgeCurve, sideOffsetDistance)
edgeFourOffsetPointOne = offsetPoint(endPointForthEdgeCurve, startPointForthEdgeCurve, topOffsetDistance)
edgeFourOffsetPointTwo = offsetPoint(startPointForthEdgeCurve, endPointForthEdgeCurve, topOffsetDistance)
# Exact Cover Offset Points
boundingPointOne =  offsetPoint(edgeOneOffsetPointOne, edgeThreeOffsetPointOne, topOffsetDistance)
boundingPointTwo = offsetPoint(edgeOneOffsetPointTwo, edgeThreeOffsetPointTwo, topOffsetDistance)
boundingPointThree = offsetPoint(edgeThreeOffsetPointTwo, edgeOneOffsetPointTwo, bottomOffsetDistance)
boundingPointFour = offsetPoint(edgeThreeOffsetPointOne, edgeOneOffsetPointOne, bottomOffsetDistance)
# Rectangular Bounding Box Creation
boundingBox = Rectangle.ByCornerPoints(boundingPointOne, boundingPointTwo, boundingPointThree, boundingPointFour)
# Translating the Bounding box to placement location
# try :
rectangleCurveOffset = Curve.Offset(boundingBox, dummyOffsetDistance)
geometryOne = Geometry.Explode(rectangleCurveOffset)
surfaceNormal = Surface.NormalAtParameter(surface[0], u, v)
surfaceNormalReversed = Vector.Reverse(surfaceNormal)
surfaceNormalReversedPoint = surfaceNormalReversed.AsPoint()
surfaceNormalRecersedXYZ = XYZ(surfaceNormalReversedPoint.X, surfaceNormalReversedPoint.Y, surfaceNormalReversedPoint.Z)
translatedGeometryRebarCurve = Geometry.Translate(geometryOne[0], surfaceNormal, -offsetFromFace)
translatedGeometryRebarCurveIList = List[Curve]()
translatedGeometryRebarCurveIList.Add(translatedGeometryRebarCurve.ToRevitType())
""" On the above line it requires curve but it says i provided line. """
try :
	rebar = Rebar.CreateFromCurves(doc, RebarStyle.Standard, rebarType, rebarHookType, rebarHookType, selectedElement, surfaceNormalRecersedXYZ, translatedGeometryRebarCurveIList, RebarHookOrientation.Right, RebarHookOrientation.Right, True, True[Dynamo File](https://drive.google.com/file/d/15Cv2bj49DfR9l3NgR9m0LIgbZRb71YYD/view?usp=drive_link))
""" translatedGeometryRebarCurveIList :  I am also getting exception here on the above line """
except Exception as ex:
	dialog = TaskDialog("Header")
	dialog.MainInstruction = "Exception In CreateFromCurves"
	dialog.MainContent = ex.ToString()
	dialog.CommonButtons = TaskDialogCommonButtons.Close;
	dialog.DefaultButton = TaskDialogResult.Close;
	dialog.Show()
OUT = geometryOne # Nevermind the OUT
I attached the dynamo file with this post. My problem is I want to create Rebar from curves with the the values i have but it shows exceptions. But it is fine working on Design Script. Let me know if I made any error or help me solve this problem.
PointOffset.dyn (71.0 KB)
I suggest you start here.
https://www.learnrevitapi.com/
Thanks for your advice pyXam, I’ll do that. But that code was not written by GPT. I converted the design scripts as python code. Chat GPT is not aware of Revit API to the larger extent. If it is that much brilliant, There will be no need for me to ask here. I got this issue while converting Design script to python. I also attached my dynamo file. Thanks for answering.
Sorry, i was having a bad morning and the dyn. Is not attached, i assumed otherwise.
Can you please re attached the dyn file so we can have a look.
