I am trying to copy existing RebarContainers to new elements and after “exploding” the RebarContainer into Rebars, but I am getting an internal error if I try to get the RebarContainerItem hook types and use them to create the new Rebars. If I give hookTypes a value of None all works well.
Please take a look at my code and let me know if you have any ideas what I am doing wrong.
Please post the code as preformatted text as well
And you should at least add a on ‘‘else’’ statement to the end of your ‘‘if’’
Hope this is better.
rebars = []
# Start transaction
for containerItem in container:
rebarStyle = doc.GetElement(containerItem.RebarShapeId).RebarStyle
barType = doc.GetElement(containerItem.BarTypeId)
hookTypeStart = doc.GetElement(containerItem.GetHookTypeId(0))
hookTypeEnd = None #doc.GetElement(containerItem.GetHookTypeId(1))
element = doc.GetElement(container.GetHostId())
origin = doc.GetElement(container.GetHostId()).Location.Point
curves = containerItem.GetCenterlineCurves(True, True, True)
hookOrientationStart = containerItem.GetHookOrientation(0)
hookOrientationEnd = containerItem.GetHookOrientation(1)
rebar = Rebar.CreateFromCurves(doc, rebarStyle, barType, hookTypeStart, hookTypeEnd, element, origin, curves, hookOrientationStart, hookOrientationEnd, True, True)
if containerItem.LayoutRule == RebarLayoutRule.FixedNumber:
rebar.GetShapeDrivenAccessor().SetLayoutAsFixedNumber(containerItem.NumberOfBarPositions, containerItem.ArrayLength, containerItem.BarsOnNormalSide, containerItem.IncludeFirstBar, containerItem.IncludeLastBar)
elif containerItem.LayoutRule == RebarLayoutRule.MaximumSpacing:
rebar.GetShapeDrivenAccessor().SetLayoutAsFixedNumber(containerItem.MaxSpacing, containerItem.ArrayLength, containerItem.BarsOnNormalSide, containerItem.IncludeFirstBar, containerItem.IncludeLastBar)
elif containerItem.LayoutRule == RebarLayoutRule.NumberWithSpacing:
rebar.GetShapeDrivenAccessor().SetLayoutAsMinimumClearSpacing(containerItem.MaxSpacing, containerItem.ArrayLength, containerItem.BarsOnNormalSide, containerItem.IncludeFirstBar, containerItem.IncludeLastBar)
elif containerItem.LayoutRule == RebarLayoutRule.MinimumClearSpacing:
rebar.GetShapeDrivenAccessor().SetLayoutAsNumberWithSpacing(containerItem.NumberOfBarPositions, containerItem.MaxSpacing, containerItem.BarsOnNormalSide, containerItem.IncludeFirstBar, containerItem.IncludeLastBar)
pass
rebars.append(rebar)
# container.ClearItems()
# End transaction
OUT = rebars",
I tried a new approach and now it works fine. I used the CreateFromCurvesAndShape() method instead of CreateFromCurves() to create the rebar, and ComputeDrivingCurves() method to get the curve of each Rebar.
Still if someone figures out why the first version did not work or if you have suggestions how to improve this script I am open to any advice.
# Enable Python support and load DesignScript library
# Import RevitAPI
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB.Structure import Rebar, RebarContainerType, RebarContainer, RebarShape, RebarBarType, RebarHookType, RebarLayoutRule
from Autodesk.Revit.DB import LocationPoint, XYZ, FilteredElementCollector, ElementFilter
container = UnwrapElement(IN[0])
# Place your code below this line
# List of Rebars
rebars = []
# List of errors
errors = []
# Start transaction
# Get the RebarShape of the current containerItem
rebarShape = doc.GetElement(containerItem.RebarShapeId)
# Get the RebarBarType of the current containerItem
# Get the RebarHookType at the start of the current containerItem
hookTypeStart = None;
if containerItem.GetHookTypeId(0).IntegerValue > 0:
# Get the RebarHookType at the end of the current containerItem
hookTypeEnd = None;
hookTypeEnd = doc.GetElement(containerItem.GetHookTypeId(1))
# Get the host of the RebarContainer
# Get the Normal of the containerItem
norm = containerItem.Normal
# Get the curves of the current
curves = containerItem.ComputeDrivingCurves()
# Get the HookOrientation at the start of the containerItem
# Get the HookOrientation at the end of the containerItem
# Try to create the Rebar
try:
# Create Rebar using CreateFromCurvesAndShape method
rebar = Rebar.CreateFromCurvesAndShape(doc, rebarShape, barType, hookTypeStart, hookTypeEnd, element, norm, curves, hookOrientationStart, hookOrientationEnd)
# Check what is the LayoutRule of the current containerItem
# Set the layout of the Rebar as fixed number
# Set the layout of the Rebar as maximum spacing
rebar.GetShapeDrivenAccessor().SetLayoutAsMaximumSpacing(containerItem.MaxSpacing, containerItem.ArrayLength, containerItem.BarsOnNormalSide, containerItem.IncludeFirstBar, containerItem.IncludeLastBar)
# Set the layout of the Rebar as number with spacing
# Set the layout of the Rebar as minimum clear spacing
# If no LayoutRule do nothing
pass
# Add the new Rebar to the rebars list
# Catch error if unable to create the Rebar
except Exception as inst:
# Add error to the errors list
errors.append(inst)
# End transaction
# Output list containing a sublist of Rebars and a sublist of errors
output = []
output.append(rebars)
output.append(errors)
OUT = output
