How to create Rebar From Curves using Revit API and Python
Hi everybody,
I’m using the Revit API method to create rebar free form curve as indicated here, but I’m stuck how to iterate at the same time in the Normal verctor list (Normal_vect) and its corresponding curve list (crvs) to be able to create the rebar doc…I thought to use zip function but I dont know how can I write the correct syntax to iterate in each sublists nested in my two lists (I want to keep the structure of my list)
here my graph:
Note: ignore the error until I haven’t correctly write the correct syntax of the function zip to iterate between curves list and vector list
Here my code:
Rebar
import sys
clr.AddReference('RevitAPI')
# dynamo curves as input
geo = IN[0]
bar_type = UnwrapElement(IN[1])
host = UnwrapElement(IN[2])
vect = IN[3]
# converting dynamo curves to Revit curves
crvs = []
temp = []
for l in range(0, len(geo)):
    for c in geo[l]:
        temp.append(c.ToRevitType())
    crvs.append(temp)
    temp = []
# get nornal vectors of each curve
Normal_vect = []
for l in range(0, len(vect)):
    for v in vect[l]:
        temp.append(v.ToRevitType())
    Normal_vect.append(temp)
    temp = []
rebars = []
for i in range(0, len(crvs)):
    for j in crvs[i]:
rebars = [Rebar.CreateFromCurves(doc, RebarStyle.Standard, bar_type, None, None, host, j, i, RebarHookOrientation.Left, RebarHookOrientation.Right, True, False) for i, j in zip(crvs, Normal_vect)]
OUT = rebars
Thanks.
@christian.stan
I received your reply in my email but I can’t see it in the forum??
@c.poupin
I tried something using zip function but I dont know if the iteration over curves and vectors outcome, because I get an error message:
for more details, please find below my last code, dyn file and Revit file
Note: for surface selection you should select the model bottom surface
Rebar
import sys
geo = IN[0]
vect = IN[3]
crvs = []
temp = []
    for c in geo[l]:
    crvs.append(temp)
    temp = []
Normal_vect = []
    for v in vect[l]:
    temp = []
# iterate over sublist in Normal_vect list and crvs list
for i, j in zip(Normal_vect, crvs):
    rebars = []
    #iterate over each item in sublists to create rebar doc  (v = normal vector and c = curves )
    for v, c in zip(i, j):
        rebar = Rebar.CreateFromCurves(doc, RebarStyle.Standard, bar_type, None, None, host, v, c, RebarHookOrientation.Left, RebarHookOrientation.Right, True, False)
        rebars.append(rebar)
OUT = rebars
fer_radier.dyn (22.5 KB)
Raft_rebar.rvt (2.2 MB)
Radier_chateau_eau_1000.rfa (440 KB)
Thanks.
You must add the Structure namespace to have access to the Rebar class (otherwise you must specify the Structure domain in your code Structure.Rebar.CreateFromCurves(doc, Structure.RebarStyle.Standard.....)
After there must also be the .Net class import (List and / or Ilist) (really not sure)
import System
from System.Collections.Generic import List,IList
too obscure for me with my current level, that’s why I deleted the message not being sure, I didn’t want to waste your time in a direction that may not be necessary
Cordially
christian.stan
Hello, with great difficulty I succeeded, (but hey I think there must be much faster)
from Autodesk.Revit.DB import*
from Autodesk.Revit.DB.Structure import*
import System
curv_dyn=IN[0]
reb_typ=UnwrapElement(IN[1])
col=UnwrapElement(IN[2])
vec_dyn=IN[3]
rc=[]
temp=[]
#vec=vec_dyn.ToRevitType()
for k,l in zip(range(0, len(curv_dyn)),range(0, len(vec_dyn))):
    curv_l=List[Curve]()
    for i,j in zip(curv_dyn[k],vec_dyn[l]):
        curv_l.Add(i.ToRevitType())
        r=Rebar.CreateFromCurves(doc,RebarStyle.Standard,reb_typ,None,None,col,j.ToRevitType(),curv_l,RebarHookOrientation.Right,RebarHookOrientation.Left,True,False)
        temp.append(r)
    rc.append(temp)
    temp=[]
OUT=rc
cordially
christian.stan
Hi @christian.stan
Thanks for your Job
I tried your code but I get an error which saying me:
error
Avertissement:IronPythonEvaluator.EvaluateIronPythonScript l’opération a échoué.
File “”, line 35, in
Exception: The input argument “barType” of function Autodesk::Revit::Proxy::DB::Structure::RebarProxy::CreateFromCurves or one item in the collection is null at line 558 of file E:\Ship\2022_px64\Source\Rebar\RebarDBAPI\gensrc\APIRebarProxy.cpp.
Parameter name: barType
here my code:
rebar
import sys
from System.Collections.Generic import IList, List
geo = IN[0]
vect = IN[3]
rc = []
temp = []
for i, j in zip((0, len(geo)), (0, len(vect))):
    curv = List[Curve]()
    for c, v in zip(geo[i], vect[j]):
        curv.Add(c.ToRevitType())
        rebar = Rebar.CreateFromCurves(doc, RebarStyle.Standard, bar_type, None, None, host, v.ToRevitType(), curv, RebarHookOrientation.Left, RebarHookOrientation.Right, True, False)
        temp.append(rebar)
    rc.append(temp)
    temp = []
OUT = rc
Can you please try your code in my Revit model above?
Another question: since the Structure.DB is part of Revit.DB why I should import it a second time??
Thanks.
I used a custom node from Mr. Fudala
you ‘‘may need’’ to install this one since it comes from bartype
during the 1st import we scan the namespaces to Autodesk.Revit.DB
during the 2nd import we add the possibility of having access to the classes of Structure more directly
But then I’m a beginner, don’t forget that
Cordially
christian.stan
@christian.stan
I already select rebar bar type from Structural Design Package!!..(Have you tried your code in my model to check if you got the same error?)
We use * to import everything from Autodesk.Revit.DB so why we call Structure.DB for a second time??
you have forgot range in first for
edit: you have forgot too import System
edit:2
and concerning:
I had tried to explain with my words and ‘‘understanding’’ in the previous post
someone more alert than me may take over on this aspect
cordially
christian.stan
because namespaces are different, need to import both (although there is an inheritance system between)
it would be useful if the models you share were not purged, the structural families are missing (or you have copy and paste the model on a non-structural template project)
@c.poupin
Thanks for your explanation about the Revit API namespaces and their uses domain!
I corrected my script and the rebars are created correctely.
Now, I want to group the rebars with the sames length in a set, so how to do that?
Thanks.
Please start a new topic as that is a different issue.
