Hi!
I want to create a railing along a curveloop, but i am not sure how to to implement the function in my script.
This is the function i want to use:
public:
static Railing^ Create(
Document^ document,
CurveLoop^ curveLoop,
ElementId^ railingTypeId,
ElementId^ baseLevelId
http://www.revitapidocs.com/2018.1/34a36770-964a-60eb-5ad7-c013913dfd05.htm
Here is my code in Python so far:
railType = UnwrapElement(IN[0])
curves = IN[1]
level = UnwrapElement(IN[2])
revitCurves=[]
for curve in curves:
revitCurves.append(curve.ToRevitType())
cLoop = CurveLoop.Create(revitCurves)
railing = Autodesk.Revit.DB.Architecture.Railing.Create(doc,cLoop,railType,level.Id)
I get the error:
TypeError: expected ElementId, got CurveLoop
If i move around the arguments so that it says:
railing = Autodesk.Revit.DB.Architecture.Railing.Create(doc,railType.Id,level.Id,cLoop)
It says it wants RailingPlacementPosition, so it seems i am trying to use the function:
public:
static ICollection<ElementId^>^ Create(
Document^ document,
ElementId^ stairsOrRampId,
RailingPlacementPosition placePosition
http://www.revitapidocs.com/2018/1c9de88b-8038-4ac9-37bd-9b6fd5e1f801.htm
How do i call the correct function given at the top?
and what are the correct inputs?
Here is a screenshot from dynamo to the script:
Edit: forgot to add a screenshot
Edit2: Running Revit 2019 and Dynamo 2.0.1, don’ know if that changes things
