How to create the railing not in all of the floors
I would like to ask about how to create railing in the opening element such as floor. I have tried [Railings- Auto place by selecting surface] the node, but it will create in all of the floors, in every rooms. I want to make the railing as a protector, so the railing will be created if there is no wall in all of the edges or there are in the two sides but no in the other two sides.
@Patton , hi
The path i would get by investigating your geometry in a clever :wink:
2022-06-30_17h14_29
2.) part works partly
clr.AddReference('RevitAPI')
clr.AddReference('System')
railType = UnwrapElement(IN[0])
curves = IN[1]
level = UnwrapElement(IN[2])
revitCurves=[]
for curve in curves:
	revitCurves.append(curve.ToRevitType())
curveloop = CurveLoop.Create(revitCurves)
Autodesk.Revit.DB.Architecture.Railing.Create(doc,curveloop, railType.Id,level.Id)
code has error :confused:
2022-06-30_17h34_35
You’re missing import Autodesk library. Add the below line after “clr.AddReference(‘RevitAPI’)”
2022-06-30_17h44_52
so whats going on here? @Kulkul
That’s because you have wrong input type at IN[0]. Railing is System Family. Use the below method to feed Railing Type:
i can just get placed railing types… and a new error occure!
You should connect only one “Element of Type” which you want from the names list. Currently you’re connecting Names list.
it remains @Kulkul
RailingPath_V01.dyn (42.1 KB)
Thank you for your help. But I still can not make the railing also.
The end of my node is null
Looks like you didn’t follow my instructions. Here is the graphical explanation:
import sys
curves = IN[1]
revitCurves=[]
railing = Autodesk.Revit.DB.Architecture.Railing.Create(doc,curveloop,railType.Id,level.Id)
OUT = railing
Hi @Patton
Possible to share relevant rvt and dyn file?
ImportCAD_20222905.rvt (6.8 MB)
Railing 2.dyn (44.4 KB)
I tried to use dyn above. please check it
How can you get the node without any error? Can you share your node?
I still get an error.
