Is it possible to use Dynamo to create a new set of project files (rvt) from multiple template files (rte) ?
I’m getting null outputs when I try to do it. My goal is to create three new RVT project files from three different revit templates. Any input would be appreciated.
Also, just to be sure, I checked with File.Exists block to make sure that the template files were present. I also tried to use a single template to create multiple new files - but the results were the same.
Hi, is it possible to select revit elements (walls, windows, roof) and import or export them into a new separate revit file ?
Hey @erfajo. Does the “File.NewProject” node still exist somewhere since “DanEDU Dynamo” is deprecated? I don’t see it in Orchid.
Thanks!
