Create Plan, RCP & Elevation for Room in linked model
Hi was trying to create Plan, RCP & Elevation for room in linked mode i got this error for Floor plan please check and suggest if you got any solution thanks
ROOMS - Create Elevations, RCPs and Plans from Linked File by level.dyn (152.1 KB)
Hi
If you’ve generated spaces (on your host model) from the architectural linked model, you can use them instead of linked pieces.
Tried with space but got this error
Hi @yuvanrajan what @c.poupin show works, but guess you have some not valid rooms try filter them out and insert an end transaction before feed in…
