Hi! I need help to understend how to get to part division properties from given wall part. I have to set division part gap.
Here is what i came up with and stuck
I understand this is an old post, but wondering if @Igor ever resolved this
here an example how to get Material Part
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import net library
from System import Array
from System.Collections.Generic import List, IList, Dictionary
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
def toList(x):
if isinstance(x, list):
return x
elif hasattr(x, "GetType") and x.GetType().GetInterface("IEnumerable") is not None:
return x
else :
return [x]
lstelems = toList(UnwrapElement(IN[0]))
lstElemIds = List[ElementId]([x.Id for x in lstelems])
out_material = []
if PartUtils.AreElementsValidForCreateParts(doc, lstElemIds):
PartUtils.CreateParts(doc, lstElemIds)
doc.Regenerate()
for wall_Id in lstElemIds:
temp = []
partsIds = PartUtils.GetAssociatedParts(doc, wall_Id, True, True)
for pId in partsIds:
part = doc.GetElement(pId)
matId = part.get_Parameter(BuiltInParameter.DPART_MATERIAL_ID_PARAM).AsElementId()
temp.append(doc.GetElement(matId))
out_material.append(temp)
OUT = out_material
