Create Floor with Python Script (First script)
Hello Everyone,
I have started my journey in learning to use the API in Dynamo. This is my first script and I cant figure out why it doesn’t work. I was attempting it in baby steps. I wanted to create a floor with this profile I created (all very simple while I figure it out). I receive this error. I was hoping someone could look at it and tell me what I am doing incorrectly. Thanks a lot for your help. (I choose to do something that already have an existing node for 2 reasons: 1. The knowledge knowing, If it doesn’t work it is because of me and 2. I would like to try the ToDSType (true))
*My script in progress I know the issue is within the NewFloor command
# Import RevitAPI
clr.AddReference("RevitAPI")
dataEnteringNode = IN
fl = IN[0]
type = IN[1]
lvl = IN[2]
struc = IN[3]
dynofl = []
dynofl2 = []
dynofl = fl.ToRevitType()
x =  doc.Create.NewFloor(dynofl[0],type[0],lvl[0],struc[0])
y = x.ToDSType(True)
OUT = [y]
Hello Everyone,
I am still trying to work through this python script. This is what I have so far:
# Import RevitAPI
fl = IN[0]
type = UnwrapElement(IN[1])
lvl = UnwrapElement(IN[2])
struc = IN[3]
dynofl = CurveArray()
for c in dynofl:
	dynofl.append(c.ToRevitType())
x = doc.Create.NewFloor(dynofl,type,lvl,struc)
OUT = [dynofl]
The Error that I am getting now is “Could not compute the plane with the input curve”. I think the way I am inputting the geometry into the CurveArray() is the problem but I cant figure out how to change it. Would someone mind throwing in any tips or resources I can read to solve the issue. As I try other methods like feeding lines into the array I still get the same results. Any help would be great thanks.
Not behind a computer at the moment, so I can’t check, but you are iterating over dynofl and then appending to that same dynofl. That should probably be something like this:
for c in fl:
Also because you are creating a new object that is not yet Revit owned, you should set the ToDSType to false: ToDSType(False)
for more info: https://github.com/DynamoDS/Dynamo/wiki/Python-0.6.3-to-0.7.x-Migration#elements
Hello T Pover,
Thanks for your help. I corrected that mistake you pointed out. The error I get now is “‘CurveArray’ object has no attribute append.”
The .ToRevitType changes the rectangle to “Autodesk.Revit.DB.NurbSpline”. I thought those could not go into a CurveArray. Therefore I created 4 lines to place into the Array and was given the same error. I looked on the SDK about the CurveArray it has not provided any insight on where I am going wrong with this script. Thanks again for your help.
Ah, I see the problem. It’s with a capital ‘A’. So it should be dynofl.Append()
Have you tried doc.Regenerate() before creation?
Thanks again for your help everyone!
@Thomas_Mahon Thanks, I have not tried it yet. I have placed it in my script. I will place my code below
@T_Pover Thanks I corrected that error. I am not getting the message" Could not construct a proper face with the input curves to create a floor correctly". I tried using the same outline in the node that comes with Revit and it works fine. Therefore I tied using 4 lines. I first got the error that my lines did not create a continuous loop. After adjusting the order of the lines and got the same error " Could not construct a proper face with the input curves to create a floor correctly": Here is my code so far (I change it to accept the 4 lines instead of the 1 rectangle):
# Import RevitAPI
fl = UnwrapElement(IN[0])
struc = IN[3]
revitfl =[]
for z in fl:
	revitfl.append(z.ToRevitType())
doc.Regenerate()
for c in revitfl:
	dynofl.Append(c)
doc.Regenerate()
OUT = [dynofl,revitfl]
What exactly is going into input IN[0] now? A Revit element?
I have 4 lines that create a rectangle.
I guess it somehow doesn’t recognize the loop as closed. If I try this it does work (with a slightly altered code):
# Import RevitAPI
fl = IN[0]
struc = IN[3]
for c in fl:
	dynofl.Append(c.ToRevitType())
doc.Regenerate()
y = x.ToDSType(False)
OUT = y
Thank you very much for your help!
I tried what you have done using R15 with 1.2 Dynamo and I receive the same error. I then switch to R17 and it worked fine. I find that weird. I will investigate so I can understand.
I really appreciate you helping though this.
