Create new numeric parmater in material
I want to add new numeric paramter in material by material name
Hello, is this possible natively in Revit?
cordially
christian.stan
There is already one there called “Mark” :smile:
Ah, seriously though, I dont know if this is possible so my alternative would be to use one of the currently not used parameters instead of making a new one.
I’ve been down this rabbit hole a few years ago, and my conclusion then was that you cannot add parameters to materials in this way.
Maybe things have changed nowadays (this was with Revit 2020)
Hi @ENGRMA1234
You can add “Custom Parameters” to Material Category. However, the parameters you add are not listed in the main part of the interface (where you would like them, in your screenshot).
You can access them in the bottom left hand side of the Materials Browser:
Hope that helps!
