Hello All!!
I am trying to change the parameter such as Name, Description, and Class in Material Browser. But I couldn’t figure out how to do that!!
Is it possible to change these parameters using nodes or python script in Dynamo?
Hi @sang87yun,
You can change the values of the parameters like this :
Python script to set the material class:
#Alban de Chasteigner 2020
# Import RevitAPI Classes
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import Material
materials = UnwrapElement(IN[0]) if isinstance(IN[0],list) else [UnwrapElement(IN[0])]
names = IN[1] if isinstance(IN[1],list) else [IN[1]]
for mat, name in zip(materials,names):
mat.MaterialClass = name
OUT = materials
I really appreciate it. Your solution was really helpful for me to solve the problem!!
The error is strange because we don’t have a line 37 in the python code.
Can you try with this .dyn file ?
material properties.dyn (18.3 KB)
