Create nested list
You already have those from the node feeding into List.CountOccurances don’t you?
Maybe you should try List.Sort instead?
You can try with node List.OfRepeatedItem
Amigo @pics.munmun buenas, try with the node OffRepeatedItem, feed whit the same values!!
I Tried, but this is not what i want.
That’s a bit weird. Then u can try to set lacing to shortest. Or also you may chop unique elements list by using List.Chop before connecting to OfrepeatedItem node
Put them in level 1 both imputs.
This is a more appropriate solution. It seems you already have everything, you just need to sort it. Right now, you’re removing data only to add it back.
