List.MinimumItem node
hi ,
i am trying to get the minimum values from nested lists. i have used the List.MinimumItem node and i am expecting it to produce a minimum values per nested lists. But its producing minimum values and merging the lists
  1. why isn’t producing minimum values in accordance to input nested list
Thank you
In the List.MinimumItem node change the levels.
thank you for your reply i have tried this modifying levels will increase overall lists
for example
L3
L4
but i am expecting something like this
Is there a reason you are wanting OOTB nodes to do this when the Python solution is giving what you require? Anyway, here is a way to match your structure using List.Rank and List.Chop :slight_smile:
WTF, haven’t you tried the @L2 ??
look at bottom of node preview, your list level to “check for minimum” is @L2 not above.
