Haaaa… I think I have installed it successfully! I will play with it and see what I can do to solve my problem…
THank you so much for your time!
check out the sample files…awsome!
I quickly made a diagrid mesh (with Python) as inputs for the ShapeMatching goals. RegularTriangles.dyn (50.3 KB)
To smooth out the wrinkles, you can modify the initial mesh so that it has some thickness (rather than just flat triangles), similar to what showed in the AU2018 class video.
Wow… you’re amazing! Thank you so much. I watched the entire video you sent me and thought I could try the One with length constrain together with shape matching… and yeah, I would add thickness to represent the actual thickness of the panel to be fabricated to be sure it can be constructed. Thank you so much!
@LongNguyen
Hi mate, Great work you’ve done there.
This problem is same with me and been trying to find solutions.
My question is will this work in squares? instead of triangles.
@archjahzzy
Hi there. Have you already solved this problem ma’am?
If yes, could you also share how can I solve because I’m having the same problem as yours, the
only thing different is we required a modular SQUARE panels from a freeform surface.
