Create lines from gridlines
Hi All,
I’ve create my gridlines by using the node Grid.ByStartPointEndPoint and I want to convert thoses gridlines to lines to be able to create my beams…so how to do that?
Thanks.
Hi @REDO10,
You can try with the Element.GetLocation or Element.Geometry nodes and if it doesnt’t work with the Element LocationCurve node from the Genius Loci package.
Hello…you could try ootb it should work as well :wink:
Hi @sovitek,
Sorry I dont understand what’s maen ootb??
Thanks.
I just mean these node there comes with Dynamo when you install it…"standard nodes…or OOTB out of the box nodes
