Create line between 2 lines
I’m trying to create a center line, between 2 lines… i wrote in the imagem below what i need…
Perhaps a line by best fit through all start and end points would be simplist here?
Could also get the vector between the start points, cut that in half, and translate the first line by that distance.
straight line version
curves interpolated version
@jacob.small, can you please tell the name of Dynamo package that will be downloaded for the node Curves.Dividecurve.
here is a possibility
Cordially
christian.stan
