Create Level by Elevation and Name with Python
I am trying to create levels using ByElevationAndName revit node using python script.
Goal here is to convert the unit based on a string input (I or M) and create levels at the correct elevations,
but can’t seem to figure out why I keep getting an error “AttributeError: ‘type’ object has no attribute ‘ByElevationAndName’”
Level name, elevation and the the units are from an excel file.
Hey,
Maybe this helps? Just some dummy numbers and things while I was digging around… The use of an alias and removing ‘Create’ are, I think, what you’re after…
If I get stuck, I tend to go back to the most simple example I can :slight_smile:
import Revit.Elements as RE
OUT = RE.Level.ByElevationAndName(30, "Test3")
Cheers,
Mark
Thanks!
