Please your help to create the geometry according to the attached image. The geometry is framed with the red line. The height is 15 cm and 25 cm at the ends.
Regards,
David
Regards,
David
Hello David Martinez,
It is not that straight forward to achieve this in Dynamo it requires lots of Geometry operations.
I have done that in attached graph. (See below image.)
Do let me know if you are looking for some different solution.
Thanks,
Ritesh
Geometry
Hello Ritesh,
Thanks for responding.
I knew it would be difficult to make the geometry, which is why I requested their support. I’m working on a project with Revit and part of the design is certainly create some complicated geometries. Finally, I think we’re going to have to do it directly in Revit. How complicated it can be to create this other enclosed geometry (Consider only the shaded white section).
Thanks,
David
