I’m trying to create rule-based filters that would hide all sections not placed on a specific sheet.
I have created an elementary graph with OOTB nodes only, performing roughly the following routine:
- Collect all views in project (the sample project contains two sections only, each assigned to a different sheet, so no furher processing is needed)
- Collect the parameter Sheet Number for each view and create a FilterRule of type NotEqual based on the parameter value.
- Create a ParameterFilterElement for each rule for the category Sections.
At step 3, I get a warning and nothing happens
The sample project contains one manually created filter which works as desired. Is it possible to create such a filter with OOTB nodes or with the API?
sheetNumberFilter_BySections.dyn (39.1 KB)
testModel_SectionFilters.rvt (432 KB)
