Create filter from Excel data, wrong value on Revit
Hello everyone,
I’m trying to create filters automatically from an Excel File.
It works fine but the filter’s values do not match the Excel’s values.
I do not know where the values in my Revit’s filter come from.
For example, in the pictures below my value is 34,42 whereas in Revit i have 10,4912.
Thanks in advance,
Sébastien
Can you show your whole graph? I cannot see where the data is coming from or what you are doing to it.
Hi Steven,
Thank you for your reply
This is my graph:
Tell me if it is clear enough,
Edit: I found the problem. My revit parameter is defined as a lenght type instead of a value. Is there a way to convert a value in a length? I tried with the node Convert Between Units but it rounded my values off.
If its a length parameter you can use string from number (Name might be a little off)
Well i tried again with convert between units meter to feet and it works without rounding my values.
Thanks Steven to reply me
Great work. Can you please share your dyn file?
