Write values from an excel file into a family doc, as parameter values
I have an small excel table example. The original is bigger. There are rows with different configurations and columns with parameters. These parameters are already created in a Revit family (with non existing values). Now I like to choose a row in Dynamo and transfer these values from excel to the instance parameters in the Revit family.
I have prepared the lists. Her can u see the result in the green groups:
The whole script looks like this:
Maybe I do something wrong with the “Set Active Family Parameter By Name” Node [data shapes package]. My attempt was to set the datatype of the values, because only the text parameter are working.
How can I change the data type of the values, depending on the data types extracted from the revit family parameters? Is it necessary?
According to the Parameter type, I need to convert the units. E.g. an length parameter needs a different conversion as an area parameter. Any idea how to choose automated the correct conversion?
Excel table:
konfigurationen.xlsx (9.7 KB)
Script:
konfiguration.dyn (55.6 KB)test_family.rfa (332 KB)
Hi @Thomas_Vogt1
Remove Double Prime(") Symbol from your code block and multiply by 3.28 using “*” node to convert m to ft.
ty Kulkul,
the code block is just an simple example. I have Parameter with length, text, volts, area etc and not all should be multiplied by 3.2808. Because of that, I have extracted the Parameter types from the family and according to the parameter types I need different conversions.
@Thomas_Vogt1 In that case use Formula or IF node to convert the values by specific types.
looks like I have solved it. Just the Length and Volume value is not exact correct because of the unit conversion (34 is now 33.965):
maybe someone has a easier solution to convert the display units to revit internal units?
Hello, maybe with Clockwork nodes (DisplayUnit.ToInternalUnit and InternalUnit.ToDisplayUnit)
The use of DisplayUnit.ToInternalUnit is not without problems with a list of all types of parameters. You need to remove text and integers first and lacing to longest =) But the conversion of the units is more precise than my first manual calculation method
Solution:
https://1drv.ms/i/s!Ar9xxoyu3-Zhhtpr2fRBl5J8RDaNgw
