Hi all,
I am using the create family parameter from Genius Loci to create a parameter for a newly created type of a family. However I can’s seem to import the right arguments in the node. I am attaching a pic. Any guidance would be highly appreciated.
Thx.
Giorgos
Hi @giorgosJ3YCR,
Are you in the Family Editor ?
Can you show the whole graph with previews enabled under the nodes ?
I am attaching the routine for you to see. I just don’t know what the arguments IN[0->6] actually refer to.
Thx,
typeFamilyCreation.dyn (46.8 KB)
I don’t understand what you’re calling
In a family, the creation of a parameter is common to all family types. However, it can be an instance or type parameter.
Please take a look in those 2 attempts I made and let me know if you can how come the names of the parameters are not recognized in either of the 2 dynamo routines.
typeFamilyCreation_Test.dyn (58.6 KB)
typeFamilyCreation_Test2.dyn (50.7 KB)
I believe the issue is the parameterGroup input. I don’t think that node will allow you to create a built-in parameter. I used Data and it created the parameter. Also, you can only run that script in the family environment.
FYI, you can use FamilyDocument.AddParameter if you are wanting to add a parameter to a family within the project environment.
In the last builds of Revit/Dynamo, there are some nodes to work with family documents.
You can’t mix nodes for Revit project and nodes for family editor.
To duplicate a family type in the family environment, you need the appropriate node.
Ditto for setting a parameter value in the family environment.
As @staylor wrote, the PG_LENGTH group can’t be use to create parameters.
Nodes for the family editor mention it in their description.
I advise you to start by properly mastering Dynamo before embarking on the Revit API and the Python language. The Revit API is full of detours and roadblocks.
