Multiple elevation views for multiple walls
Hi experts
I am trying to use a modified learning module script to create multiple elevation views on multiple walls. I’ve searched around the forum for a solution and some people suggested i flatten the list but that didnt work - then i get another error.
Any idea what i can do to fix the script?
Error snapshot and .dyn file attached below
LearnDynamo_Module_2 (dynamo 2.0) V2.dyn (90.6 KB)
@michelFTJKX ,
better to show your code… :wink:
clr.AddReference('RevitAPI')
from math import *
toggle = IN[0]
point = UnwrapElement(IN[1])
modelPoints = UnwrapElement(IN[2])
cropCurves = UnwrapElement(IN[3])
viewType = UnwrapElement(IN[4])
lst = []
#Get Family View Type
vft = 0
collector = FilteredElementCollector(doc).OfClass(ViewFamilyType).ToElements()
#eleViews = []
for i in collector:
	if i.ViewFamily == ViewFamily.Elevation:
		vft = i.Id
		break
if toggle == True:
		#Retrieve the mid point of model lines and get X,Y.
	modelMP = modelPoints.ToXyz()
	modelMPX = modelMP.X
	modelMPY = modelMP.Y
		#Retrieve individual lines of crop window.
	cropLines = cropCurves
	l1 = cropLines[0].ToRevitType()
	l2 = cropLines[1].ToRevitType()
	l3 = cropLines[2].ToRevitType()
	l4 = cropLines[3].ToRevitType()
		# Create a line in the z-Axis for elevation marker to rotate around.
	elevationPT = point.ToXyz()
	elptRotate = XYZ(elevationPT.X, elevationPT.Y, elevationPT.Z+100)
	ln = Line.CreateBound(elevationPT, elptRotate)
		#Calculate the angle between Model Mid Point and Elevation Point.
	elevationPTY = elevationPT.Y
	elevationPTX = elevationPT.X
	combY = elevationPTY-modelMPY
	combX = elevationPTX-modelMPX
	ang = atan2(combY, combX)
		#Create elevation marker and elevation in position 0.
	eleMarker = ElevationMarker.CreateElevationMarker(doc, viewType.Id, elevationPT, 100)
	ele = eleMarker.CreateElevation(doc, doc.ActiveView.Id , 0)
		#Rotate elevation marker towars model line.
	ElementTransformUtils.RotateElement(doc, eleMarker.Id, ln, ang)
	crManager = ele.GetCropRegionShapeManager()
		#crShape = crManager.GetCropRegionShape()
	newCurveLoop = []
	newCurveLoop.Add(l1)
	newCurveLoop.Add(l2)
	newCurveLoop.Add(l3)
	newCurveLoop.Add(l4)
	cLoop = CurveLoop.Create(newCurveLoop)
	try:
		crManager.SetCropShape(loop)
		lst.append("Elevation Created")
	except:
		pass
		lst.append("Missed Elevation")
	OUT = lst
	OUT = "Set toggle to TRUE"
Hi @michelFTJKX ,
See if this helps:
