hello, and I’ve been trying to edit the radii of an alignment so that the radii smaller than 200 become spiral and the ones greater than curve, I have already been able to round the radii and separate them but I still haven’t got what I want someone has an idea that course I must take
I attach the files used
Drawing1.dwg (1.0 MB)
radios.dyn (18.6 KB)
You’d better attach the image of the shape you want. instead of your python. Why is it in dwg???
I do not understand your answer, I am attached file and dynamo
This is what can see in your dwg…
I thought I could help if i saw the shape in the dwg you want. But I couldn’t.
How strange, capable is the version of civil 3d, because I downloaded it and if it is appreciated, I still reload the file…
If someone could clear my doubt about how to generate curves and spirals
Drawing1.dwg (925.9 KB)
Oh, it’s about Cvil3D which is I don’t use.
I’ll see what I can do If you provide your input and the output you want in general geometry level.
Hay un tema similar, pueda que te sirva.
Anyone having Excel import trouble today? Computer ran windows updates 2 days ago and suddenly I cant import Excel. note that i also installed Autocad and Navisworks 2022 yesterday as well. This is Revit 2020 - Dynamo 2.3
[ExcelError]
