Help with Python Script for Autocad
I am really new to Python and trying to create while loop in Python script node of Dynamo. bellow is my efforts without any knowledge of python and basic search on google for while loop. so pardon me if its full of mistakes and errors, it would be really great if someone can guide me to get this sorted.
attached dyn for reference.ttr_test.dyn (31.7 KB)
hello @shahid.shaikh_C3D
try to add a tab
read this
Thanks for the reply @c.poupin. though it will be difficult for me to understand this coding language, took some baby steps as per the article and corrected the script. still seems i am way out of track ? apart from indent do you think anything else needed in the code or workflow is correct ?
ttr_test.dyn (31.8 KB)
you are defined 2 alias you can use them
Hi @c.poupin Apologies for the late reply…
took some time and help and worked on the script …good news is its working now, but it wont exit the loop and never complete the run.
Please suggest if it can update the loop somehow
Hi @shahid.shaikh_C3D,
If you want to simplify things, you could remove lines 59-74. They are for handling transactions with the AutoCAD/Civil 3D database via the API, which doesn’t appear to be your goal.
a simple example to create a circle in Civil3D from a Dynamo Geometry
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
dataEnteringNode = IN
editor = adoc.Editor
center = IN[0]
#create a proto Geometry
circleDs = DS.Circle.ByCenterPointRadius(center, 50)
with adoc.LockDocument():
    with adoc.Database as db:
            # Place your code below
            acBlkTbl = t.GetObject(db.BlockTableId, OpenMode.ForRead)
            acBlkTblRec = t.GetObject(acBlkTbl[BlockTableRecord.ModelSpace],  OpenMode.ForWrite)
            acCirc = Circle()
            acCirc.Center = Point3d(circleDs.CenterPoint.X, circleDs.CenterPoint.Y, circleDs.CenterPoint.Z)
            acCirc.Radius = circleDs.Radius
            acBlkTblRec.AppendEntity(acCirc)
            t.AddNewlyCreatedDBObject(acCirc, True)
            # Commit before end transaction
            t.Commit()
OUT = circleDs
@c.poupin thanks for reply…its not a simple circle. if you look at the code, its trying to find the center and radius from a loop and at the moment its not exiting loop.
