Hello all, I have a question: How can I create commands inside Revit properties using Dynamo and make, for example, the wall move when I insert coordinates into these commands? My point is I want a pretty window for inserts of what I want to change. Thanks
Hi @husamaljawhar,
Welcome to the Dynamo Forum.
The use case you describe would probably be better with an addin.
However, you could use Dynamo Player to get a minimalist interface.
Hi @Alban_de_Chasteigner ,
Many thanks for your answer, and I will keep this option. But according to an article I am reading now describing what I mansion in my previous inquiry by using IFC Schema, and I want to follow this article, but it does not describe the steps. Can you help me with that?
Thanks,
Husam
Your subject is not clear.
Please read the guidelines : How to get help on the Dynamo forums
The forum brings together a lot of people who want to help but this requires having tried something beforehand.
