Create color scheme with dynamo, how?
Is there a python-node or a package that support create colour-scheme via dynamo
i would prefer to create via .csv list?
KR
Andreas
Hi @Draxl_Andreas,
it is possible with the Genius Loci package but only with Revit 2022.
Like @Alban_de_Chasteigner said:
it is possible in Revit 2022…
https://www.revitapidocs.com/2022/bdc51109-355d-dc7d-9b43-c59ab1357479.htm
Oh no we use Revit 2021!
I have to find a way in python can i change this at least or is it more complex:
clr.AddReference('RevitAPI')
clr.AddReference('System')
scheme = UnwrapElement(IN[0])
out = []
elems = FilteredElementCollector(doc,Scheme.Id).ToElements()
for scheme in FEC(doc).OfCategory(DB.BuiltInCategory.OST_ColorFillSchema):
    if scheme.Name == 'Raumnutzungsart':
        scheme_entries = scheme.GetEntries()
for i in IN[1]:
	new = ElementTransformUnils.CopyElement(doc,elems[0].Id,XYZ(0,0,0))
	elem = doc.GetItem(new[0])
	elem.LookupParameter("Raumnutzungscode").Set(i[0])
	out.append(elem)
OUT = out
or it means the API comment is in 2021 not aviable ?
It is not possible in R21, only in R22 or newer as time goes. The API does not expose it before that.
FYI: Here is how I have done it in R22. It uses the same principal as the Key Schedule graph, but it get a single entry, changes the info, then adds that to Scheme.
