Create automatically WALL from AUTOCAD TO 3D
Hi there, i think i missed something, it doesn’t work. I want to transform my wall from Autocad to 3D
Need some help please !
Thanks a lot
Simon
Try this way
It’s work one time only… Can’t repeat execution
Also, when its work i have this :
Run the same script using Dynamo Player,
Thank you but i have 2 walls instead of 1 (see my screenshot in my comment before)
Yes, As per your script, you have lines form CAD file and placing center of wall along the line.
if you want one wall, then modify the cad layout with one line (center of the wall) run the script.
ok thanks a lot its work !
