Create and raise custom errors
I have been trying to implement Python Exceptions in order to control the flow of the dynamo code and inform the user (in case of using the file in Dynamo or in Dynamo Player) so they know what the problem is. It could sound a bit odd but sometimes the input have to accomplish some conditions (as in levels to have different names, if not revit is going to crash).
I have already create a python code that raise an exception with a message that shows only in dynamo workspace and stop the processing returning a null object. Nevertheless, if i add-in this code inside a custom node the error is invissible and no message is seen. I would like to achieve the full view of this message anyway, in the custom code box and inside the Dynamo Player space.
This is the code i used inside my custom node, but it only shows inside of it, not in the general sheet.
Thank you very much
Hi @Alvaca and welcome
maybe you can create your custom Exception class with a message box
an example
import sys
import System
clr.AddReference('System.Windows.Forms')
from System.Windows.Forms import MessageBox, MessageBoxButtons, MessageBoxIcon
class ValidationError(Exception):
	def __init__(self, typeError = "Error", messageError = "An error occurred"):
		self._typeError = typeError
		self._messageError = messageError
		Exception.__init__(self, self._typeError)
		self.CMessageBox()
	def __str__(self):
		return "{} : {}".format(self._typeError , self._messageError)
	def CMessageBox(self):
		MessageBox.Show(self._messageError, self._typeError, MessageBoxButtons.OK, MessageBoxIcon.Error)
pt = IN	[0]
if pt.Z > 3:
	raise ValidationError("Point Error", "Z value is too high")
OUT = 0
Thank you very much @c.poupin. It works as I wanted to, it is perfect.
I just changed the code so it fits with my code necessities and everything go as it has to.
I add my code in case anyone is interested in my specific case:
# Carga las bibliotecas de DesignScript y normas de Python.
import sys
# Las entradas de este nodo se almacenan como lista en las variables IN.
dataEnteringNode = IN
dataInput = IN[0]
isDuplicated = IN[1]
# Incluya el código debajo de esta línea
		self.CMessageBox()
	def __str__(self):
if isDuplicated:
	raise ValidationError("Input Error", "Los nombres y cotas de los niveles deben ser diferentes")
	OUT = dataInput
