When Run Dynamo script, shows me this error in Python script !
Try io.StringIO instead.
Have you tried just importing io?
Yes, give me the same error.
I want to upload the script, but it is not available to me ![]()
You can cut and paste the code?
Someone may be able to help more easily then.
import sys
import System
import re
my_path = System.Environment.GetFolderPath(System.Environment.SpecialFolder.MyDocuments)
pf_path = System.Environment.GetFolderPath(System.Environment.SpecialFolder.ProgramFilesX86)
sys.path.append(pf_path + '\\IronPython 2.7\\Lib')
from io.StringIO import StringIO
sys.stdout = StringIO()
import time
from datetime import timedelta
import traceback
import ctypes
def Mbox(title, text, style):
return ctypes.windll.user32.MessageBoxW(0, text, title, style)
import logging
import math
clr.AddReference('System.Windows.Forms')
clr.AddReference('System.Drawing')
clr.AddReference('System.Windows.Forms.DataVisualization')
clr.AddReference("System.Drawing")
clr.AddReference("System.Windows.Forms")
import System.Drawing
import System.Windows.Forms
from System.Drawing import *
from System.Windows.Forms import *
from System.Drawing import Point , Size , Graphics, Bitmap, Image, Font, FontStyle, Icon, Color, Region , Rectangle , ContentAlignment
from System.Windows.Forms import Button,Label,ListView,Form,CheckState
from cStringIO import StringIO
import os
import webbrowser
import unicodedata
try:
errorReport = None
column_names = IN[0]
sublist = column_names
result = []
for n in range(len(sublist)):
items = [i for i, x in enumerate(sublist) if x == sublist[n]]
if items not in result:
if len(items) > 1:
result.append(sublist[n])
if len(result) != 0:
msgren = "You have Duplicate Column Names in Excel \\nDuplicate Column Names are: {}".format(str(result))
output = Mbox('Error!',msgren.replace('set(', ''), 0x10)
output = sublist
except:
# if error accurs anywhere in the process catch it
errorReport = traceback.format_exc()
if errorReport == None:
if output != 1:
mandatory = ["Element type Name","Layer Name"]
if all(s in output for s in mandatory):
OUT = output
OUT = Mbox('Error!','Element type Name and Layer Name Missing in Excel Columns', 0x10)
OUT = output
OUT = Mbox('Error!',errorReport[errorReport.find('line'):]', 0x10)
I copied it, but it is now hidden from the system via Dynamo.
Try
from io import StringIO
