I am created a dynamo for set a different worksets for different piping systems. I can used this dynamo is only used for current project , if I want to used this dynamo in other project then I need to updated the dynamo as per project piping system.
is this possible to create a rule for set workset to the systems even systems is not present in model?
Thanks for your suggestion, I have changed Dynamo as per your suggestion.
I can used this dynamo is only for current project because it select current project pipes 7 fittings and changed the workset but if I used this dynamo for another project and some piping system is not used in that projects then I need to check and changed the lists in the dynamo. Is their any way to set a rule for the same.
Is there any solution on this one? I’m looking for something simular.
The above script works well for one project and with a lot of custom work. Is it possible to somehow search for a specific word in the pipe/duct systems and search for the same word in the worksets in the project - and then match those when chaning the worksets?
So if “I6000” is present in a system name and also in a workset name, then these are matched and the workset will be set for that system?
