I use Dynamo1.3
I want to create a label for the door
like this
But I tried to build but found the problem
door標籤test.dyn (15.2 KB)
I am a beginner, please exhibitions, thank you
I use Dynamo1.3
like this
What isn’t working in your graph? How have you tried to fix it? A little more description of the issue would help us to help you.
Thank you for your reply
I would like to make every floor of the door, do the automatic label (on the floor plan, as shown above)
But found not working
Do not know where the problem is, or the use of the wrong node?
Please advise, thank you
Something is happening in your “+”, String.Insert, and List.Combine Nodes. Are you trying to add a string to the end of the Level.Name? If you can so the output values of the + and String.Insert it would help.
I try not to use the problem node, the level.Name directly linked to
Element.SetParameterByName
The following results are obtained
But I want to use DYNAMO and automatically display the door label in REVIT
How to do it?
Ok, so from what I follow you want to place a door tag on all the doors. So far you’ve done well by writing the “2FL” to the Mark parameter. To place a tag on the door, use the node Tag.ByElement. This will place the default tag of that element category on those elements.
You’re welcome. I’ll mark it as solved.
