Creat wall pieces from hatch
How can I create a script to automatically convert hatch walls into individual wall pieces in a large architectural project?
I’m going to ask why… It’s not usually a great idea to have 100s of individual items in a model.
We need to see the joints in BIM360 so, that’s why we need to make it as a pieces
Hi @omar.driouich i would say as Alien, but if you will play around with something…then try something here…PS and show us what you have tried in dynamo so far…
Revit_t0BOqxh5fG
For the joints I would recommend drawing lines or hosting families instead of making parts from the wall as it’s N+M lines instead of N*M tiles.
thank you Mr.Sovitek for helping me,
could you please share this script with me, there are some nodes I didn’t find in the dynamo.
this is the same idea that I am looking for
If you really must see each and every tile, the simplest thing to do is to switch this to a curtain wall where each curtain wall panel is just a wall (tile). Joints can be "grout: mullions if you like - or no mullions.
No programing needed.
And easy to switch back to one regular wall if you want.
I use genius loci [pattern dimension reference] and ampersand [split], synthezise toolkit [wall by surface]
