Creat view from Offset Revit wall - Urgent
I have a set of walls (just created some randomly) and I want to create a line parallel to each wall using dynamo instead of doing each one manually.
I believe these nodes should help you get started.
Element.location.
Polycurve.FromCurves.
Curve.Offset.
Try something with them and post what you get and the community will help as we can.
Small correction here @jacob.small “Polycurve.ByJoinedCurves”. There is no node called Polycurve.FromCurves.
@yragab7 Here is what @jacob.small was trying to explain.
Ah so close!
Good catch @Kulkul
Thank you very much. I’ll try it now.
