I don’t know how to put the Value in the filter
Hi @dangvandung86
See if this helps as an example.
Parameter value: “System Type” is not a string or text value. Can you help me with my .dyn file? If you run the dyn file you will understand exactly the problem I am having. Many thanks
Test_Dynamo.dyn (59.1 KB)
It isn’t supposed to be in this cas (AFAIK)
I suggest you try to make changes like my example and see what that gets you.
Hi @dangvandung86 here is a way with archilab, hope is what you are after…if i understand ![]()
Thank you very much. This is exactly what I needed. I also don’t understand why the Equals value is not compatible in these dynamo nodes
