Hi RVTing, welcome to the forum
Please review the forum FAQ here How to get help on the Dynamo forums
So you have two problems here
How to get all the wall joints of walls with the same external finish (possible to have different types with the same external finish).
Clockwork have a node that can get the compound structure information like materials
Then grab all the walls and check their joins and if they are connected to a wall with the same material -
How to check if the external face wall angle is ‘internal’ concave (0 - 180 degrees) or ‘external’ convex 180 - 360 degrees.
This can be done by using the wall orientation (External facing normal vector) and a vector of the walls location difference (see here c# - Is this Edge of a 3D solid Concave or Convex? - Stack Overflow)
I think what you are trying to do here is fairly advanced - is this just for one project or will it be used on many?
Anyway - have a go and come back to the forum when you get stuck
