Could u please share dynamo script for develop the duct model using cad single line drawing with different sizes of duct
hi its almost impossible to give you a solution…many thing is about how good the cad is draw[gap,overlab etc.] and probably need to split the lines in every T-cross fitting and all is on right layer with a signal for size…
thank u. can we able to develop at least this type of duct routing ? different sizes.
hi i dont have any cad…but something here could be a start…here i use open mep package…
byFfUdhFQx
awsome, i have one option i will convert the cad lines into revit detail lines, then i will use this. thank u sovitek. can u send .dyn file ?
i m not able to zoom the view and not able to view the nodes names.
yeah try as here
duct example.dyn (44.8 KB)
thank u for sharing, but “OpenMEP” package is not able to install. i am using revit 2023 ver.
that package use an extern installer can be found here, or use mepover from package manager with similar nodes
