The node Corridor.Baselines fail when importing baselines from the corridor having feature line as baseline.
what could be the possible solution to import such baseline?
Could you show us the error message and make a screenshot more large to see what is the input of your node here?
Known limitation in Civil 3D API
ok. So, there is know other way I could extract the corridor feature lines for such corridors in dynamo?
A workaround could be to use dynamo to create an alignment and profile from the feature line then switch the base line in program?
Or maybe extract them as dynamic corridor feature lines in model space and then use Featureline.ByName?
Thanks! this worked for me
I used Featureline.ByObject instead.
I’ll give it a try. Thanks
Hi.
Can you explain that?
I’m in the same situation and i dont’ know how to get featurelines from the objects (corridors)…
Im really new in dynamo.
You can use the following Nodes under Civil3DToolkit package:
or else you can also use this node from existing default nodes:
Hi.
I know this nodes, but none of them works with featureline-based corridors…as far as i know.
And how have you used the featureline.byobject node?
Or did you extract the featurelines by hand before?
Hi. I have similiar problem. Even if I extract featureline by hand and use FeatureLine.GetFromObject I dont know how to read start and end station of the extracted feature line and how to read feature line coordinate system. CorridorFeatureLine.CoordinateSystemByStation doesnt accept selected feature line (even if it is Auto Corridor Feature Line).
