Copy Space parameters to Family Parameters
Hi guys,
I was wondering if it’s possible to copy 3 space parameter values to families that are inside those spaces.
Let me give you an example…
I have 3 spaces in my Revit model.
Those spaces have three parameters (instance):
A
B
C
Space 1:
A = 2
B = 3
C = 1000
Space 2:
A = 3
B = 200
C = 5
Space 3:
A = 5
B = 20
C = 55
Each Space have a FCU except Space 3 .
Space 1 => FCU 1
Space 2 => FCU 2
Space 3 => None
Those Fcu’s have also parameters A B C.
I would like to copy parameter values A, B and C from Spaces to FCU’s that are inside those Spaces.
So FCU 1 will have parameter values:
A = 2
B = 3
C = 1000
and FCU 2 will have parameter values:
A = 3
B = 200
C = 5
I had a look on others posts and I’ve found this solution:
What do you think if I will use Element.BoundingBox and then BoundingBox.ToCuboid instead of using FamilyInstanceLocation?
Another thing is:
Is it possible to have a list of Spaces that don’t have any FCU? (in my example will be Space 3) So everything will be under my control.
Thanks guys
Here is an example that transfers one parameter from space to family instance within the space…
Parameter-SpaceToFamily.dyn (9.3 KB)
Thanks Vikram… it works :slight_smile:
Hi Guys,
I have another issue with the script that Vikram gave to me. If there is more than one FCU in that space the script doesn’t work.
What should I do?
Should i use the node “FamilyInstance.Space” ?
in that case what should be the script?
Thanks for your help :slight_smile:
