I’m trying to copy a selection filter from a view template I named “Desactiver_Maquette” who have just the filter I need to copy to all the view template of my project.
Maybe Copy and pasting isn’t the right method to use…
I work on Dynamo but I can also understand C# macro.
Let me know your issues.
Salut Thomas
Try this (in Python)
#import Revit API
clr.AddReference('RevitAPI')
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
#Get Important vars
def getfilterByName(nameFilter):
collfilter = FilteredElementCollector(doc).OfClass(FilterElement).ToElements()
if collfilter:
filterSelect = [x for x in collfilter if x.Name == nameFilter]
if filterSelect:
return filterSelect[0]
else: return None
nameFilter = IN[0]
outViews = []
filter = getfilterByName(nameFilter)
if filter:
collViews = FilteredElementCollector(doc).OfClass(View)
viewsTemplate = [x for x in collViews if x.IsTemplate]
#Processing
TransactionManager.Instance.ForceCloseTransaction()
for vTemp in viewsTemplate:
if vTemp.AreGraphicsOverridesAllowed():
if filter.Id not in vTemp.GetFilters():
vTemp.AddFilter(filter.Id)
outViews.append(vTemp)
OUT = outViews
OUT = "Filtre introuvable"
Merci beaucoup !
Petit plus, savez-vous me dire quoi rajouter après vTemp.AddFilter(filter.Id) pour faire en sorte que le filtre sois désactivé par défaut ?
Merci d’avance.
Thank you so much !
For more, can you tell me what I have to put after vTemp.AddFilter(filter.Id) to deactivate filter when it is in the view template.
@Thomas_LiB
using the method SetFilterVisibility
#import Revit API
#Get Important vars
if collfilter:
if filterSelect:
else: return None
nameFilter = IN[0]
outViews = []
if filter:
#Processing
vTemp.SetFilterVisibility(filter.Id, False)
OUT = outViews
OUT = "Filter not found"
There is a way to get Selection Filter overrides and set it to another views?
Hello @Ezequiel_Zicca_Jacqu and welcome!, it’s better to start a new topic, because the topic is old, and your request is a little different.
Think before any request to use the search engine
https://forum.dynamobim.com/search?q=copy%20filter%20overrides
