Hi I set up a script with the help of a post here, the scripts runs with no error but I don’t see results in Revit. Please I need help. I am still new with dynamo.
You don’t have all the inputs for the CopyElement node. A light gray header means that the node is returning a function and not actually running. You need to provide the link instance as well.
As for why the Get All Elements node isn’t returning anything… it’s hard to say without any context. What does the output look like? Is it giving you a traceback error? Have you looked at the contents of the custom node?
Spring-Nodes has excellent nodes for this.
Be sure to check the likes / dislikes when searching for the package. There is an “imitator” which has negative likes. You want the package with positive likes ![]()
