I would like to run studies on multiple computers overnight and then assemble them back on one computer by copying the needed files.
I assume the data is stored here:
C:\Users*Username*\AppData\Roaming\GenerativeDesign
But what files would need to be copied and can this even be done?
I was merely pointing you to the folder where Studies live in case you need to move the studies as well. You seem to be asking about Outcomes (the results of a given Study) which are located in the folder you mentioned. Outcomes (hist_results) are identified by a GUID. I’m not sure if there’s a way to identify which Study an Outcome is from without just checking the outputs though.
Thanks Nick
I was aware of the studies location but I will take a closer look at hist_results and see if anything works.
